A little background...My head pipe bolts backed out last weekend just enough to ruin the gasket. I put on a new gasket with some copper gasket goop to seal the marks that were left from the metal core and retorqued everything. While I was in there, I squirted everything down with purple power because the engine bay was a mess from the pipe being loose.
I went out to ride today and everything seemed normal for a couple minutes. Then it started feeling like either the prop was cavitating or the single channel total loss ignition was bouncing off the rev limiter. Both were only noticeable when quickly going to full throttle. If I stay below 1/2-3/4 throttle everything is normal, the ski still has loads of power and plenty of bottom end snap. If I were to just try to get up to speed normally, it's still fine but a quick yank of the throttle makes it nutty.
The prop and stator vanes look good and I tightened my electrical connections which were slightly loose. Fuel tank isn't leaking and I can't find any leaks in the fuel lines. My only thoughts are the purple power ate something it shouldn't have, the total loss brain is going out, the total loss flywheel or stator plate are loose, or the pump shoe came loose. I think most are a long shot though.
