Compression checking?
NJ
Do you test the compression on a 08 Superjet just like a boat?
Remove the plug wires on both cylinders and plug in the jug you want to test, hook up the tester, give her a couple cranks on the starter and read compression???
cmeripper26
Ripper26
Connecticut
Ground your wires and leave one plug in and crank till you get a reading that stays steady. then hold that reading to make sure the psi reading does not drop.
Isn't that what the R in BR9ES is for.. Resistor.. the ski's ignition requires the resistance on the the plug from a complete ground. without it there can be damage.. or so i'm told..
And get a good gauge or verify with another.. my NAPA reads 10psi low.. 150 - 160psi no biggy.. 185 - 195 mucho problemo..
