Waveraider Motor ?
WR 701 can be either 61x/61x or 62T(dual carb), depending on year and package. For at least 1 year ('96 for sure) there was a base (single carb, 61x) or deluxe (dual carb, 62T) available.
Well I'm looking at a used FFP B Pipe manifold that came off of a raider, that I need to my 61x waveblaster, I need to know if it will work on my 61x cylinders.
I have read that the 8 exhaust bolts on the 62T cylinders are bigger than the 8 bolts on the 61x cylinders, or do I have that wrong ?
I would hate to buy this FFP manifold and find out it won't work on my 61x motor.
Aircraftsalz
Thrust built Dasa Power
Off site
I think you can get a bushing to use the bigger bolt hole man on a 61X cylinder & use standard 61X bolts. I'm not 100% sure.
