Do I have a Limited or Mod expansion chamber?
NVJAY775
My home away from home.
Does anybody know the measurement I need to take to see what chamber I have? I'm guessing limited, cuz it's a tight a$$ fit. Mine end to end is close to 26.25"
And what have you guys been doing to keep it from tearing itself up and the hull from rubbing. I shimmed my waterbox away from the pipe side about 1/2" to 3/4".
My pipe is actually pretty messed up and needs a lot more welding than I initially thought. Exhaust leaks suck...
Thanks guys.
Jay
that's a limited you have....
Total Length
Mod Pipe = 25-1/2"
Limited Pipe = 26-1/2"
Circumference
Mod Pipe = 19-1/4"
Limited Pipe = 19-3/8"
Diameter
Mod Pipe = 5-3/4"
Limited Pipe = 5-7/8"
Volume
Mod Pipe = 212 US [fl oz.] or 6.270 Liters
Limited Pipe = 232 US [fl oz.] or 6.861 Liters
NVJAY775
Total Length
Mod Pipe = 25-1/2"
Circumference
Mod Pipe = 19-1/4"
Diameter
Mod Pipe = 5-3/4"
Volume
Big thanks for all the info on that. I was hoping it was a limited.
Anybody have any thoughts, or pics on materials to use between the pipe and hull? Is this a common problem?
