Weird B Pipe chamber ??
Picked this up today and noticed the weird bend on the end...was thsi for a 650...or ...??
+ the dent underneath ??
Foximus
CFL Cheapass.
Oviedo, Fl
650 chamber negative. That is a 701 fx1 chamber. Basically the same as a normal 701 limited chamber. The dent is to clear the motor mount in fx1... I use one in my js550. They were angled a bit farther in because of a narrower hull so the exit was bent a bit to angle straight towards the waterbox.
However it has been cut and shortened. You should take it somewhere to get the length back.
Mile9c1
X-H2O.com
Grand Rapids, MI
That's just an (old looking) 701 chamber. It's definitely not an FX-1 or a 650 chamber. Maybe it's an old 701 mod chamber, or a modified 701 limited chamber.
Foximus
CFL Cheapass.
Oviedo, Fl
Why would you say its not an FX1 chamber?
And yes I know they cut them from the factory, but I did not believe they did this for the fx1.
This could be a very old chamber because the Headpipe still has the elegant old style imprint of factory pipe....
- is this comparable to limited chamber, and if I straighten the end could I run it then ?
Does anyone want to trade factory 61x manifold for 62 T ?
tom21
havin fun
clearwater FL
are you looking for the t or the x? I have a t I want to trade for an x. guessing you are too:dance:
it's a mod for a 701 square nose.fpp angled them for the old boats to fit the waterbox better.
will fit a rn as well and sometimes is desirable depending on the waterbox you're running.
dent is for mount clearance.
Updateed pics...
So it does not matter that the chamber is shorther ? Or would this be more like mod chamber then ?
