Crash Vs SXI
Winter Mods..
Hull Repair and Reinforcement (Carbon)
Paint
Superjet Handle pole
Blowsion lowered bracket
Trinty Foot holds
Turf
Turf side rails
Xmetal Steering and bars
Internal Gas fill
Prop 9/17 set back swirl
Foot straps
Relocate Primer
Relocate By-pass
Relocate Fire ex
Pole limit rope
Start
Broken Bracket
Repair time
Repairs are done by Crash andFlat black sqare on our lunch hour.
Next
Repairs to the bottom and cut out sides for trinty foot holds
Filled in around motor mounts so carbon would lay down a little easier
Wolf Child
Just Another Octard
All over C. FL
I hear ya.
seriously though... when I was looking at the pics I thought it was my old ski. you even ground it out the same as I did when I was still considering fixing it.
Waternut
Customizing addict
Macon, GA
If you're going with the C-75 swirl, you'll love it but both are good. If you're going to go with an internal fill fuel cap, at least make the nose look pretty and smooth it out.
Carbon and foam
Did away with gas fill hole and started laying carbon
Paint
Learning how to paint....
Dark Grey
Green pin stripe
White bottom
Green letters
Painting the top
I got a little better but still had a few runs to work on. Flat back sqare help with the prep work and Big Fish had a few coaching tips.
Dark grey
Green numbers
Green pin stripe
White stripe on the hood
Foximus
CFL Cheapass.
Oviedo, Fl
Do you still have your torpedo tubes and caps or did you throw them away? I know they get torn up but I need where they flush into the hull!
Thanks
Foximus
CFL Cheapass.
Oviedo, Fl
I can repair or make new tubes. I just need the caps and the circle area you cut on the back of the gun whales and then 2-3" of the tube...
Hope you didnt throw them out yet.... Just need one.
