300/440/550 My 650sx w/pics i got some questions.
kawasakisxs0ul
Water is so BAD ASS
St. Louis, mo
engine bay
anyone know if this is a realllly :):):):)ty carb? should i upgrade????
i have no idea if this is a good exhaust...
grate...
anyone know what that little pull cord is? i never pulled it... i was told not to by some1
i got some1 sellign me the nose piece, HOUSEBOAT WAKE KICKED MY BUTT
3wheelerdude
Talk less, Ride more!
Ontario Canada
"I used my crankcase drain a few times after sinking the ski and never had a problem. Put it this way, use it when you have to only.
You got a nice ski with a great exhaust pipe and grate, now it looks like a 28mm carb, if it is, swap it for a 44 muikuni.
kawasakisxs0ul
Water is so BAD ASS
St. Louis, mo
you say it like its easy to swap the carbs out?? i know nothing about what to buy for adapters or anything... IF ANYONE HAS A LINK TO A PLACE TO BUY A CARB, OR WILL SELL ME EVERYTHING I NEED TO PUT IT ONTO MY SKI I WILL BUY!!!
thanks dude, i like my ski a lot.
KaosFreestyle
White on White
Mequon, WI
You will need a new intake manifold for a Mikuni. Its a worthwhile upgrade.
1st thing I noticed is the location of the bilge is not great. Should have it near the back where the driveshaft goes through the bulkhead.
TnT
I just wan na fly
Knoxville, TN
thats a nice clean 650sx, good buy. It looks like you do have a small carb.
Changing out to a bigger carb is pretty easy. What you would need to change out the carb to a 44 sbn(which has been stated before) is a adapter plate (or if you find a intake manifold, those are even better), the 44 sbn carb itself, gaskets, and possibly even an air filter. The nice thing about the stock carb that you have is the air filter itself does a pretty good job of keeping water out. The big difference that a larger carb would bring to the table is Throttle response. Which is always fun.
You have a nice exhaust pipe for sure, and the grate that is on your ski does wonders for hooking up on the water. You might want to buy a primer kit.
For now with what you have, I would just say get out and ride. Have a blast, if your ever down in Knoxville, TN. Let me know, I'll ride with ya. And welcome to your new addiction
kawasakisxs0ul
Water is so BAD ASS
St. Louis, mo
dude, im sooooooo addicted! thanks for the help!
nokfir
Merrick NY
i had a 44 on my 650. that thing was great. made a ton of low end power. def look into it, ittl change the ski entirely.
650 sx
I have these adaptors they will make a mikuni SBN 44mm fit on your oem intake manifold , you will need to have a machine shop open your manifold to 44mm or dremel it yourself, then get the carburator and you are set
SkiDiggity
formerly kawirider142
i am running a 44 with west coast exhaust and the 44 sbn was the smartest thing i did thing runs like a champ :) as for the bilge if i were you just put in in the back left corner that is what i did it works great just remove the head pipe and silicon it in :) looks alot cleaner that way too.
i will try to post pics tommorow or tuesday on how i did mine
BTW the color is BA
kawasakisxs0ul
Water is so BAD ASS
St. Louis, mo
thanks bro.. im deff going to put my billege in the back left corner tomorrow..
whats funny is 2 weekends ago the pipe coming from the exterier exaust hole was seperated from the waterbox... i took it out and filled my whole ski with water... it was so gay. i fixed it ran it and its doing just fine now.
