300/440/550 MY x2 Changed into js 550 hull
agua
FIshing for Stand ups
Seminole, Fl
Can i use all my parts from my x2 in a js550? i need to know if i can get my pump to fit [ i know i have to the get a conversion plate] but other then that will my exaust set up and shaft work correctly?
agua
Seminole, Fl
because right now my x2 has no title and i cant seem to get it worked out, so im thinking in converting it so i can ride in salt water again, getting bored of flat water and theres still a risk of getting caught, and that would be a big ticket since i dont even have stickers on my ski, no fire extingisher, or whistle or anything...
Polish jet pilot
4aces4aces4aces4aces4aces
Warsaw, Poland
only engine fgeom x2 will fit without major problems if you get a conversion plate. The pump in x2 is the same as in all other Kawi 650 skis and will not fit the 550 hull. Your best bet is to use 650 engine in 550 hull. Pump conversion is very possible but quite work intensive...
