I bought 3lb expanding foam from US composites and defoamed my entire ski over the winter. Figuring I couldn't seal the ski perfectly, I decided to install drains. Well a month ago I put it in the water for the first time and lightly rode it while breaking in the engine but the back end stayed in the water for about 2 hours total. Then when I got home and pulled the drain plugs and some water dribbled out. I continued the break in process last weekend (3 weeks later) and did roughly the same thing but rode a little more aggressively. Today, (4 weeks after initial water test) I rode for about 15 minutes and the ski was in the water for 30 minutes.
Here's the crappy part: I noticed the sealant around my scupper was gone so I pried it off to refit and reseal it. Seeing the amount of water sitting where the scupper used to be had me concerned about the foam. So far I've dug out 6-8 inches deep and 3 inches up and it's completely soaked like a sponge! :261: Less than a month of minimal water entrapment and less than 5 hours of ride time and the foam is waterlogged. :aargh4:
How is that closed cell foam?!?! I should've just used newspaper. The whole reason I bought the 3lb foam over the 2lb was because the 2lb was supposedly 3-5% open cell foam and the 3lb was supposed to be 100% closed cell. Great Stuff holds out water better than that!! :soapbox:
