- CANADA - USA
also picked up a nice X2 today
but thats another thread when i'm done with SJ!
yes its fine- install the bottom and work up. you may need to sand the holds or hull to get the best fit. like the back corner, looks like its more on the kicktail then the roundnose will allow for. you will glass over it all so don't be afraid to trim it.
if it was me I would grind the rear bottom of the hold and the rear side of the hull. you can at this point even screw them in and glass over. depends on how lazy you are. :shrug: by grinding the outside towards the bottom you will get a slightly(very slightly) wider tray. looks like the roundie rolls out at the top more than the square.
I saw a nice Factory b pipe for a 650 in the classifides.
honestly I would just do the bottom corner- the rest will pull up.
Are you going to use the stock handle pole bracket with that aluminum pole?
tom or anyone that knows:
witch tubbies go on witch side?
the sharp end goes towards nose or towards the tray?
please advice as i'm ready to install,
thanks....
While swapping handle pole you can pull handle pole bracket gusset to reinforce (the stock one will not break after doing this) and make under side plate.This will save you much grief as it will reduce the possibility of cracks around the handle pole bracket. Do you need pictures?yes was thinking to reuse stock one, why are you asking ?
umi plate is steering. The handle pole mount is down by fuel inlet. I will send pictures tonight or tomorrow morning.maybe i rather get umi plate instead?
unless reinforcement is a must even with aftermarket plate?
thanks...
