Manifold for Dual 46 Buckshots?
EightySeven550
Always just this close
Hello all, it looks like I am getting a pair of dual 46 buckshots.
Can I get my OEM Duall 44 Manifold bored out or should I get an aftermarket intake?
Also not sure about how I want to run these yet. Heres what I have/am getting let me know what you guys think.
Dual 46 Buckshots
Dual 44 OEMs
Thought of running a singel buckshot 46 ran across my mind.
Open for suggestions and criticisms.
Thanks,
Andre
954-918-5477
Kennay
Squarenose for the _____
Myrtle Beach, SC
1.) Sell buckshots
2.) Use money to send OEM carbs to Jetworks to be blackjacks
3.) Use 44mm OEM carbs that are now Blackjacks
4.) Profit $$$
super-ski (Dave) tried 44 buckshots....
1) pain in azz to dial in.
2) have gas can nearby they dump fuel !
3) hit well on midrange just ok on low end.
4) better used as a race carb not freestyle.
5) do a search...u will see same.
:grumble:
McDog
Other Administrator
Staff member
South Florida
Team Scream says the same thing about Blackjacks. It's a racing carb and not really designed for freestyle....just what I was told.
Kennay
Myrtle Beach, SC
You were lied to or either someone ignorantly told you that. I'm betting on the latter since Team Scream has a pretty good reputation.
Kennay
Myrtle Beach, SC
Why do I want to call them? Why do I care what they think about a carb that they obviously do not know much about? I know they work. I use them, and have ridden kick ass ski's that run them as well.
LBE
Eddie Would Go.
Charlotte, NC
Art at Jetworks is setting up a set of duals for me for freestyle. His suggestion, run the stock dual 38s but he taper bores and removes the bomb site. The smaller 38 can move the air through quicker on tne low end (less volume) than a set of dual 44's giving more low to mid hit. For top end you would want to blackjack and go BIGGER 46-48.
Give Art a call:949-548-5259
He is a wealth of information and can steer you in the right direction for your set up.
Kennay
Myrtle Beach, SC
I think you may have misunderstood him. He is probably recommending the 38's because you already have them, and they are all your particular engine needs.
EightySeven550
LBE and Kennay seems like either way I am going to be giving Art some buisness. I will give him acall tomorrow and explain my situation and what I have and what I am tryuing to do.
Thanks all,
Andre
954-918-5477
