eBox washer . .
tor*p*do
Squarenose FTW
NW NC
reassembled my SN and rode yesterday :Banane01:
hit the bilge switch a couple times and nothing came out
new midshaft must be a good seal
but after some cold water stabs, still no water
took it home and removed hood. whenever I hit the bilge switch
I get a steady spray of water on the back of the ebox :261:
good thing I got yanking the motor down to a drill
tor*p*do
Squarenose FTW
NW NC
Tech Support: So your E-Box washer is broke?
Nope, my HOSE was HOSED and maybe I was a little hosed when I posted :biggthumpup:
guiness92
thought I would have to, but managed to get my hand
behind the protec pipe to redo the bilge line
it probably would have been easier to pull the motor
but I got lazy
Where is your bilge mounted? That doesnt make much sense if your bilge is mounted under the coupler and your outlet is on the dash.
guiness92
if you put the outlet on the side of the dash and angle it up and over the gunwhale, very little gets in the tray. It just shoots over the gunwhale.
