Engine mounts and coupler busted AGAIN!
Motorheads5
Livin the generation gap
ketchikan alaska
These kid's of mine rednecked a 650 this last summer and through bolted all 4 motor mount's and it worked excellent no vibration issue either of course I kind of wondered about the alignment but hey it's still running fine and the coupler is still perfect.
Waternut
Customizing addict
Macon, GA
So basically those kids just stuck a bolt and a washer through the backside of the mount without the urethane bushing?
Mark44
Katie's Boss
100% one place
i know this is is an old post but it got me think'n (and thats always bad). So I went over to my buddies shop & played with his lathe & mill & this is what I came up with.
these would take care of the mount breakage problem but they may cause unwanted vibration. urethaine bushing & through bolted for support,
what do you think?
I need to get a little bit longer bolt for my alum bed plate but these should work for a stocker.
Looks like a real fine way to yank the inserts out of the fiberglass if you ask me. You may want to reconsider.
Mark44
