blaster 760 jetting
Q
QuickMick
If anyone can help me with my jetting I would appreciate it.
I put a 64U 760 in my blaster.
dual 44 stock
FP limited chamber for blaster
ADA head 38 cc domes 180 psi
no porting pretty much stock
Im at a loss where to start my jetting.
does anyone have something close with a baseline
on my jetting so where I can start??
anyone would be appreciated.
baldwin ny
you need to lose the stock carbs and intake. i have tryed and tryed to jet the stock carbs with a factory pipe it dont work. get a set of aftermarket 44's and a r@d manifold (with out the crossover) i have the jetting written down in my shop i will post it later.
Q
QuickMick
dam this is an old post woops
Thats ok. gimmie some #'s. Im taking it out to tune this weekend. I got some good helpfull info from Tim Judge.
what do you think about the buckshot carbs??
baldwin ny
with the stock 44s you always have a funny spot at the conversion from the low to mid . i could never get it out. my jetting i fixed that issue and can run w.o.t all daty long.(with after market 44')
i will post it
#ZERO
Beach Bum
Florida - U.S.A.
i will post it
You have a problem with your carbs or your jetting is off.
Remove the bottom allen screw for the bypass holes and the low speed mixture screws, you'll have deposits blocking these ports.
Jetting 760
760 Ported/B-Pipe limited/MSD Enhancer/701 61x Stator/Lighten 61x Flywheel/OEM 44mm SBN carburators/K&N Arrestors/Dual Cooled/ADA girdled Head 33cc DOMES 180 PSI/Stubby cone/Hooker 10/16 7mm cutback/
RUNS AS FOLLOWS
MAIN 130
PILOT 120
1.5 N/S ( Stock )
90 G Spring pop cant remember anymore
HIGH SCREW 1
LOW SCREW 1
B- PIPE Bottom Closed/Mid closed/ Top 1/2 Open
This was almost after 6 months of fine tuning, i could not find any better results...different opinion and jettings are out there !!
SKI RUNS LIKE A RAPPED APE...better than any 701 I ever had !!
baldwin ny
112 low 135 high 2.0 80gram spring. ada 180 factory limited pipe. dual cooling (1 of them for pipe 1 for the motor) solas k prop. bottom open 1/2 on the pipe.the rest closed.at sea level in salt water. (yes it matters)
