B-pipe dual cooling routing
tbaer
USMC
BEAUFORT SC
I know this topics has been:deadhorse: but all of the tread I have searched are so confusing. I have dual cooling and a i just put a b pipe on. can someone please draw me a diagram on how to route the cooling lines? Do I have to use a flow conrol valve? if so is there a cheaper alternative to the jet works valve which is about 40 bones? please post up a paint shop diagram showing me how.
BruceSki
Formerly Motoman25
Long Island
some people just use a restrictor instead of a flow control.
for 40 bucks its a big help... you already spent a couple hundo on a b pipe... why not just spend 40 bucks more and have the adjustability of the flow control.(my .02) i have mine set up with a zip tie holding it on so i can adjust it on the fly.
my cooling is set up in a parallel system. one line dedicated to the pipe, on line dedicated to the motor.
there are plenty of paint pictures floating around... ill try to find the one that i run.
BruceSki
Formerly Motoman25
Long Island
good info in there.
i went with this setup... but there are many setups out there and they all work... just differently.
pic is courtesy of #.0 in that thread
The Penguin
triple secret probation
here's how my 2 motors are set up (under guidance from builders - not my routing)
Motorheads5
Livin the generation gap
ketchikan alaska
Great info thank's guy's I am running my bypass to the handlebar's for heat I probably should tee that to bypass so when I want to regulate the bar heat.
Q
QuickMick
good info in there.
I must say the drawing by #.0 was drawn much better than yours Penguin.
chad
I pretty much love beer
Mine is set up the same way as Penguin 's right side drawing .. I was told that you want the cold water to cool the hottest part first.... the manifold.
This time of year I have both bypass( pissers ) diverted to hand warmers/ foot warmers.
Q
QuickMick
I took #0's drawing and modified it to reflect my routing.
but who asked you anyway? you don't even own a b-pipe. :stooges:
:bsflag: hahaha what do you think is in my blaster?
dont be scared of the dry pipe in my AV.
tbaer
USMC
BEAUFORT SC
ADA head?
i have an r and d head right now but i just got a smokin deal on an ada girdled head with 33cc domes for $80 shipped
Great info. I am glad everybody didn't come back with :shocked: "why don't you search blah blah blah...:censored:" so Thanks to every one who is actually trying to be cool and help!:fing02:
On the 94 -95 it has one big line and 2 smalls. You have the one big line set for dual cooling going to the exh mani right? the 1 small to the pipe? and what with the 3rd?
