Yamaha Handlepole Long bolt (attaching bracket to pole)... source/dimensions?
Roo
it's all good
Picked up a RRP handlepole setup...
However, I still need to get the long bolt and nut that connects the pole to the bracket (as well as a spring...).
Is this something I can pick up real quick off McMaster? I just need dimensions or even another source for run.
Thanks!
-Andrew
Roo
it's all good
do you have a stock length rn pole bolt then? can i get that off the mcmaster? sorry for kinda jackin the thread, you can just pm me
No I don't have one - I have never had a stock handlepole setup on my SJ's.
That is what I am trying to find out, if this is a bolt I can get off McMaster.
IceRocket1286
Metro Detroit
You can probably find one in mcmaster....maybe you could hit up KW cycle, im sure they can order you one if its not a rip off...since I know you won't be riding with this lovely weather.
RRP also makes a reinforcement sleeve to go inside of the bottom bracket. The pole bolt goes through it so you can tighten the bolt so your pole stays were you put it..the sleeve keeps you from possibly squishing the bottom bracket.
Roo
it's all good
NO! I am running a spring - one of the reasons I sold my XMETAL setup.
I'm wondering if anyone had the exact specs on the bolt so I could search McMaster properly.
Fla
dont forget to run a sprin on the rrp pole you need the little billet piece that goes between the tubes to hold the spring
