will bare fiberglass absorb water
G
Goose
i had some issues with my surface on a part i made so i sanded it down to bare fiberglass.i sprayed it with epoxy primer and it turned out with pinholes everywhere which i expected.my question is will fiberglass with resin already cured in absorb water
Kennay
Squarenose for the _____
Myrtle Beach, SC
With polyester, that is how blisters will form (More or less.) That won't happen with epoxy, and I am not sure about vinyl.
Why don't you just spot fill the fish eyes?
Motorheads5
Livin the generation gap
ketchikan alaska
If you have silicone anywhere on the boat it will fisheye. I know some people use silicone spray as a corosion block I don't know if that's your problem or not. I have been told that fiberglass by itself will absorb moisture it need's to be sealed or gel coated.
G
Goose
it fisheyed because i sprayed over bare fiberglass im not worried about the looks im worried about the fiberglass breaking down due to the water being absorbed
are you sure??? fisheye usually means silicone/oil, water in the air lines or cleaning the surface w/ a reducer instead of using a pre-paint cleaner. not sanding the glass would cause it to not stick too...
crammit442
makin' legs
here
I think what he's referring to is a part straight from the mold that wasn't gelcoated. There are very small porosities that cause most coatings to fisheye. The epoxy primer he sprayed in mold didn't work well so he sanded and tried to apply an external coat. Sometimes the viscosity of the coating is low enough that it won't bridge the holes. This is always a challenge when I build visual carbon parts without an in mold gelcoat. I hope that makes sense.:Thinkingof_:
It probably fisheyed because of trapped mold release (wax) in some porosity of the fiberglass part,that would be the logical explanation here.
G
Goose
it didnt fish eye its the pores in the fiberglass.when i pulled the part half the primer stayed in the mold and half was on thehull and wasnt fully cured i dont think that the primer sat long enough before i laid over it
