What is the ID of a 62T flywheel and a 61X flywheel?
godocgo
sport
s. fla
pretty sure, just measured them 2 days ago. i may be off by a 1/16 here or there.
but a 62t is definitley bigger. 62t stator will not fit inside a 61x flywheel.
I got a reply via pm from Tricky. He said
62T=4.125" ID
61X=3.820" ID
I knew one of them was approximately 4 3/16. Just didn't know which one. And I wasn't sure which one was bigger.
Thanks for the replies fellas!
Mike W
Infidel
North Florida
No Mike...what I was looking for is:
If you flip the flywheel in the pic over and measure the diameter of the inside opening where it hugs the stator. It should be 4+ inches. I need some exact numbers though
Gotcha. You need ID=Inside Diameter not ID= Identification. My mistake.
