douglee25
m3booooy
- South Jersey
Is this Brian's yellow 750?
No, my buddy from Tom's River area who I work with.
Have the battery checked by an automotive parts store that has an electrical battery conductance tester, this will give you the exact CCA and voltage.
Reread my explanation again. We used car batteries with the same result.
Did you every check the voltage at the starter while cranking or perform a voltage drop or ohm test on the cables?
No, we tried OEM cables and jumper cables, jetski batteries, car batteries. Same result.
Also double the check the resistance of your starter solenoid while it's energized, you might not be getting the sufficient amperage to your starter.
We bypassed this completely.
