Basically you raise the exhaust port 1mm and keep the stock radius,port should be 52mm wide,clean up the transfers and knife edge the dividers but do not enlarge them,there are numerous things you can do on the intake side but that is case porting,not cylinder porting.Porting is good for about 5100-5400 rpms
