i have a js 550 with westcoast pipe, hot head, reed cylinder adaptor, light porting, 38mm carb, 440 pump, and can't get it to run right. the ski ran better with the stock pipe or the factory pipe. how can i get my performance back? do i need the carb rejetted? bigger carb? etc. i was trying to run the reed adaptor with single carb only. should i go to 44mm or dual 38mm carbs to fix problem? thanks waterdog 357
