- South Florida
I got a single channel digital total loss from a fellow board member and had it shipped to Jetski solutions for John to check out and setup for me. He told me it was the worst looking stuff he had ever received. I thought that was funny because I was told it was rough looking but that it worked. I knew he could make it pretty as long as it works. John did have to repair the coil (he said it may or may not last) but didn't charge me extra for it and I put it on my ski today. The LED was burned out so I had to set the timing with a timing light. I talked to John about it and he said he didn't check the dip switches or the LED which I was kinda disappointed about. I mean, why else did I send it to him? I finally got the timing set at 29 degrees advance by subtracting 6 degrees with the brain. I set the start retard at 5000 and the rpm limit at 8000. -13 for the retard limit setting for 16 advance at 8000. set the timing with the engine running dry in my shop.
When I put the ski in the water it had no power. I didn't seem to want to rev and had no hit. It would run but would only slowly accelerate to about 20mph tops. Throttle response was non existant. Since my ski was last running I also put on a limited b-pipe, girdled head with 35cc domes, and rejetted the carbs at 135 mains, 75 pilots, stock springs, stock needle and seats, low speed 3/4 turn out and high speed 1 and 1/2 turns out as per Mike W's recommendations. My ski is a otherwise stock 1996 superjet.
I checked compression and I'm at 175 in both cylinders. I started to screw around with my carbs but I figure Mike W's recommendations and factory pipe's jetting couldn't be that far off. I'm thinking it has to be something wrong with the ignition, but I don't know. I'm so sick of wrenching on this ski that I'm tempted to take it to the local shop to have them figure it out, but that would be like admiting defeat. I'm gonna call John tomorrow and see what he thinks, but what do you guys think?
