Got the 790 big bore in, Jetinetics TL ignition setup and everything running this weekend. Feels good to have it all together, but Ive got a couple problems.
I took it out for the first ride of the season, gathered jetting specs from a ton of different setups and ended up getting info from Ross C to get a good starting point. Got it on the water and it was running okay, messed with the screws a bit and fattened up the low end to get it running pretty damn good and lightly burned up a tank of fuel. Before putting it on the water the compression was 175/175 on a cheap guage, after I got it home (it cooled down quite a bit) it read 165/175. I was a little scared by that so I pulled the head, it looks to be running a bit rich but the cylinder walls had slight scoring on them. Each one had vertical lines worn in the cylinder walls, nothing you could really feel with your finger nails but they where visible and wore away the crosshatch marks.
My questions is, if I go back through it and get my carb totally dialed will the scoring get worse or stay the same? I really dont have the coin to do a topend or even a hone and rings right now (or the motivation to pull my topend off) Part of me says, tune the carb in better, and rip it, shouldn't see any drop in performance and hone/rering this winter and another part is saying to pull it apart now and get it done.
