Ski wont start
I gotta 750 sx and i cannot get it started. It has spark and good compression. I thought it my be just flooded but i let it sit and turned it over with the plugs out plenty of times and still wont start. I was wondering what else i could check.
ger87410
How did I get here?
Fort Worth
Doesn't turn over or cough at all?
Tried drying all the gas out and then pouring a little bit (1-2 Tbps) into the carb intake?
Did it ever run (since U got it of course)?
Is the battery voltage good? When i got my superjet my battery was dead and it was at 10.43 Volts.. it could barely start. A new jetwork battery solved that problem.
aranka
usually drunk
Detroit River MI
if its not any of the above your flywheel may have slipped on the shaft causing the timing to slip. those keyway's break and the fly will slip.
ger87410
How did I get here?
Fort Worth
Great thinking, Aranka!!!
I completely forgot about the flywheel. A visual inspection w/o removal should be enough for you to tell if the keeper's jacked.
