- Reno,NV
Hi ,
I am running an odd engine set up for my back up ski and am having a problem with the throttle response and immediate low end power.
Set up is 61x/Pro tec 61x Cylinder, 650 electrics, coffmans pipe, single SBN 44mm , Westcoast head 25cc domes ( 160 PSI ) we are at very high altitude, jetting 1,5 n&S , 95 g spring 120 low, 130 high. Sparks show good ~!
And this is how it goes in tha water...
At full throttle starting out engine needs to catch up to a certain rev/speed ( no low end power ( till NOS point ) and then suddenly like someone flipped a switch and turned NOS on.... the ski has enourmous power ??? the complete upper powerband is very good..just low end feels like caviatation or slipping clutch.
NOTE: No changes to impeller/pump ( all clean no cavitation ) since last stock 701 61x/61x engine.
- POP OFF ??
- POR TEK Cylinder race ported ? not freestyle suitable ?
- Electrical issue ??
Thank you for any serious advice !
Chris
- POP OFF ??
Chris
