Was this a decent deal???
Peter123
C-Note
Houston, TX
I am really new to wrenching, what does cavitate mean?
Very basically, it means that your impellor is engaged but not generating the correct head pressure. Basically spinning without moving the proper amount of water through it.
Edit: I answer the phone, talk for just a moment or 2, and then there's another 8 replies.
Don't you people have jobs (non-goverment I mean)?
dirkdiggler
WI
I sit in a cube all day at GE Healthcare! Many websites are blocked here but X-h20.com isnt !! I dont think many people here are into watersports so they havent put the axe on this site, most are fresh from india anyways!!
dirkdiggler
WI
should the whole pump just slide off after I remove all the bolts?? I got it all apart but it will only slide back a little bit, shoudl I just pull harder??? I got the seal to come away from the housing like 1/4 of a inch but I will need more room to inspect/ fix
You mean to tell me Wikipedia is blocked at your job?
Shens.
dirkdiggler
WI
should it pull the whole shaft with it?? when I pull the pump towards the back I can see the shaft coming with it??
this is all new to me and I dont want to make more problems by breaking something!!
Shaft comes with it, you're fine.
Didn't you say you're sitting at work? Do you have the ski in the office or what?
Because it is a stock aluminum impeller. They are known to suck royal ass, and they cause cavitation. No matter how good they look.
However, your ride should be improved quite a bit now, IF you fixed the seal right.
chrisdoc0608
insulting
rocky mount, nc
I put a fine coat of grease on the seal.
Mark44
me too
if you want to get under there with a flash light when its dark and shine it through your intake grate, it will give you a pretty good idea if it sealed up well or not, if there is light coming through the seal its bad, if not go run it
