Loading up
Kawi 800
06' SXR
Harveys Lake PA
My ski has wet pipe, ada head, tdr water box stock carbs with FPP jetting, everything else is on my build page, i was wondering if anyone else was bogging down wile doing tail stands and nose stabs if not on the gas well enough to keep that water from filling up the waterbox and chamber of the pipe and if there is anyway to fix this, or just keep on trhe throttle with stuff like this.
Proformance1
Liquid Insanity
New York Crew
They do that really bad with the wet pipe on no front exhaust. Also watch it because you can overheat the motor from doing tail stands for too long. Mine hit about 300 and some degrees in about 10 sec. I don't think it will hurt, but it is definitely not going to help.
5810
WHERE-THE-SEAT-AT
Knoxville TN
Mine does it too, 180psi compression from milled head helped a little. what I do now is
when tail standing I try to keep the rear hood intakes out of water, if they go under just for a sec it start to load up mad & it takes full throttle to pull out, other wise it bogs minimum. When nose stabbing, as soon as I enter the water I let go of the throttle this keeps the carbs from loading up a lot, I let the skis boyince(cant spell the word) raise me to the top of the water & the power out.
SXR-FOREVER
Finally Flippin
Hang on to that throttle and sub straight in!!!!:headbang:
how loud is it with the side exhaust?
Loud. I'm going to run one of my pissers into the outlet to quiet it down. It might not be loud to you guys, I just am not a fan of obnoxious skiis.
Kawi 800
06' SXR
Harveys Lake PA
mine is pretty loud with front only and the dry pipe. but not so bad to completely piss people off, except for hopefully the sobecks.....
Think mine will be too bad if i just Y the pipe and have front and rear? When you getting out on the water we have already been stoped by the fish police haha
nah you should be alright, duals usually aren't to bad. when you hear how loud shaes is its not going to matter, he is just making his obnoxious....... probably going to lead to trouble.
i love the dry so far, i had it in the surf and a little flatwater in Daytona, its not perfectly tuned yet and it smokes my wet pipe in every aspect. i am just a little nervous to see how it holds up. i will let you know more in about 2 weeks when i am back on the water with the shortened hull.....
wnb800
spending green
Harveys Lake, PA
sxrforever, i wanna see how loud your ski is at the rock n ride if your there. If its not too loud with the side exhaust when you put your pisser into it i may do that... i f'n hate bog
SXR-FOREVER
Finally Flippin
I dont think I am going to make the rock n ride this year, with gas prices the hell if I can afford that. Maybe if I somehow get some money I'll make it out.
I'll let you know how it sounds after I put the pisser in though.
wnb800
spending green
Harveys Lake, PA
GOOD.. bob to the rescue. i was about to ask how your determining that theres water in the carbs anyway.
