I'm in the middle of wiring my oem start/stop and lanyard to my TL (analog). Directions are a little vague. Looking for some advice. I've got a BROWN/RED coupled together and a WHITE/BLACK coupled coming from the oem switch. The TL directions say to wire one of those sets to the pickup leads off the stator (doesn't say which set to use)??? Then run the other set to the starter relay I would assume it would be a black/red set like what's coming from battery to the relay and then to the switch. I don't know which wires to run to pickup leads and which ones to connect to relay?
Next question is for the purple wire coming from brain. Wiring schematic shows it connected to a seperate lanyard switch then to an aftermarket on/off switch and then to the + batt term. Can I just forget the other lanyard and run the purple(from brain) to on/off switch then to + term.?
Last question, do you boys run a fuse between the battery and brain on your TL setups? If I have to I need to go get a fuse holder.
