yup.... it finally happened
wydopen
onthepipe
your about to case that....motos for people that cant swim
i have a hard enough time when my suspension is off by one or two clicks... i cant even imagine a dual sport suspension going into braking bumps or going over a big double.. yikes...
Wolf Child
Just Another Octard
All over C. FL
hey 'Saki.. to you do any woods riding?
I'd like to get a bunch of us together to do surf and then bikes while I'm down there the first part of may.
let's make this happen.
I need stats on your bike saki...
I think you will be suprised w/ this KTM... It looks and feels like a full on dirt bike.. Nothing like that thing above...
in mx, it's really all about suspension. you can roll up to the track in a bone stock bike off the showroom floor and lap the entire field. motor means nothing to guys like us. good suspension, however, will make you 10x faster quickly... not to mention save your life when you get in trouble. :bigeyes:
This is why you see very few dated bikes at the track. this is the biggest diff between skiing and mx. with the skis, it's almost mandatory to have the oldest, most beatup boat (NICE boats are for posers). In mx, it's not so, you WANT to have the latest/greatest, at least frame/suspensionwise. mx stuff changes every year, it's not stale like the jetski crap is that never ever changes. they put millions into R&D'ing bikes every year.
.02
2006 Yamaha YZ450F
Stats:
Manufacturer Yamaha
Model Year 2006
Model YZ450F
Color Two-tone Team Yamaha Blue / White
ENGINE
Engine Liquid-cooled, 5-valve, DOHC, 4-stroke with titanium valves
Displacement 449 cc
Bore x Stroke 95 x 63.4 mm
Compression Ratio 12.3:1
Fuel System 39 mm Keihin FCR flat-slide with throttle position sensor
Clutch Multi-plate wet
Ignition Digital CDI
DIMENSIONS
Length 86.3 in.
Width 32.1 in.
Height 51.1 in.
Weight 220 lbs.
Ground Clearance 14.6 in.
Wheelbase 58.9 in.
Fuel Capacity 1.85 gal.
Seat Height 38.8 in.
DRIVETRAIN
Transmission 5-speed
Final Drive #520 chain
Suspension Front: 48 mm Kayaba inverted telescopic fork w/adj. compression & rebound damping; 11.8 in. travel
Rear: Kayaba single shock w/adj. preload, compression & rebound damping & separate hi/lo-speed compression adjuster; 12.4 in. travel
BRAKES/WHEELS/TIRES
Brakes Front: 250 mm floating disc
Rear: 245 mm disc
Tires Front: 80/100-21-51M Dunlop
Rear: 110/90-19-62M Dunlop
Edit: i see your bike comes in at 226lbs, pretty impressive.. but its still just a two stroke.... zzzZZZzzzzzZzzzzzzz
Model:KTM 250 EXC
Year:
2005Category:Cross / motocrossEngine and transmission
Displacement:249.00 ccm (15.19 cubic inches)
Engine type:
Single cylinder
Stroke:2
Compression:11.0:1
Bore x stroke:
66.4 x 72.0 mm (2.6 x 2.8 inches)
Fuel system:
Carburettor. Keihin PWK 36 S AG
Ignition:
Kokusan digital 2K-3
Starter:
Kick
Lubrication system:Mixture oil lubrication 1:60
Cooling system:Liquid
Gearbox:5-speed
Transmission type
final drive:
Chain
Clutch:Wet multi-disc clutch, operated hydraulicallyPhysical measures
Dry weight:102.6 kg (226.2 pounds)
Seat height:
925 mm (36.4 inches) If adjustable, lowest setting.
Ground clearance:
385 mm (15.2 inches)
Wheelbase:1,475 mm (58.1 inches)Chassis and dimensions
Frame type:Chromium molybdenum
Rake (fork angle):27.0°Trail:116 mm (4.6 inches)
Front suspension:
WP-USD 48 mm (1.89 in.)
Rear suspension:
WP-PDS-shock absorber
Rear suspension travel:335 mm (13.2 inches)
Front brakes:
Single disc
Front brakes diameter:
216 mm (8.5 inches)
Rear brakes:
Single disc
Rear brakes diameter:
260 mm (10.2 inches)
Other specifications
Fuel capacity:
8.50 litres (2.25 gallons)
wydopen
onthepipe
maybe.
jetskis are for people who are either afraid of mx (aka pu$) or their mommies/wives won't let them.
:nana:
i used to ride....now its a poser sport like all the rest :biggthumpup:
dont do it nick...best decision i ever made was selling my crf...
