Any ideas how to get a stand up and sit down on the same single trailer?
has any one ever put a sit down 3 seater and a stand up on the same single caravan trailer? im coming down to key west but id much rather take my 30mpg car then my buddys 13mpg truck down.... i just need to find out how to have a car tow 2 skis on a single place trailer..
any one ever do this?
its a kawi stx or somthing like that.. and my 03 superjet.
if any one has any ideals lemme know!
and it cant have 3713713719 pounds of toungue weight.
ger87410
How did I get here?
Fort Worth
Also, check the axle/tires to make sure it can take the added weight.
I was going to change my single to a double, like you described, but it'd barely handle the weight and the axle wasn't wide enough for my liking.
How far apart are the tires? What's the width of your 2 skis?
the side rails of his ski come even with the inside of the tires of the trailer. it does have bigger wheels and tires. idk if i should suck up the extra ton of gas money and just deal with it or try and do this conversion.. + id love to get some sick pics of my car in floridia.
slide his back and put yours in front. then pull the couch tight against the SJ.
This way you will move the heavier ski back and if something fall off. you still have your ski
Doug
ger87410
How did I get here?
Fort Worth
Whatever you do, put the greatest amount of weight forward of the axle.
You never want the tongue to lift up when not connected to something (like a hitch).
Maybe? http://www.autoworldaccessories.com/script/newcategorypage.asp?category_id=1363
Kennay
Squarenose for the _____
Myrtle Beach, SC
I'd just borrow someone's utility trailer (Or a double ski trailer).
Make sure you rinse it good after splashing it down in keywest though. :)
