"There are four total waterlines on a Super Jet with a Pro-Tec pipe. Below
are the explanations of each water line.
#1 - Stock incoming waterline from jet pump connects to brass fitting on
bottom side of Pro-Tec exhaust manifold.
#2 - Pro-Tec waterline from brass fitting on rear of cylinder head connects
to water fitting on right side of Pro-Tec headpipe.
#3 - Pro-Tec waterline from fitting on left side of Pro-Tec headpipe
connects to brass fitting at small end of Pro-Tec expansion chamber.
#4 - Pro-Tec waterline from brass fitting on front of cylinder head connects
to water bypass fitting. Water bypass fitting is not included with pipe or
head kit and must be purchased separately. Do not use a water bypass fitting
larger than 6mm."
