Vumad
Super Hero, with a cape!
- St. Pete, FL
Please post information you have on Kawi 750 engines here.
Specifically I am looking for information having to do with crank sizes and porting and etc.
Tom and I were discussing information on different 750 engines. The 750 engine was made for several years. There is a big pin and small pin version. There are different boats the engine was in (750 STS, 750 XI SS, 750 SX, 750 SXI, 750 SXI PRO). The topic of porting was brought up. Does the small pin engine from my sit down have the same porting (and expected perfomance) as the same year stand up? or are they ported differenty for different types of performance?
For example, I just found the following information about 750 porting. While it is not specific, it does address porting changes in the 750 engine. It does confirm that the change from small to big pin is not the only change to the stock form of the 750 engine.
As i understand it, all 750 engines '94 and older were small pin, which means they have a lighter crank and better bottom end performance. engines '95 and newer are big pin and generate more horsepower, but have a heavier crank to get it, so less bottom end than a small pin. but... how does the porting in our engines change from engine to engine? how does this affect our expected performance? I want bottom end!
Please post specific differences in the engines from year to year and model to model as you find it.
The changes to carbs and exhausts is not terribly relivant, because most of us change those out, but it is certainly useful information, and welcomed. I don't know if any of the 750 engines used different flywheels or electronics that would change performance.
This isn't really the proper place to talk about 650 electronics. The discussion is about changes to the 750 engine based on year and model.
PS. The porting changes mentioned are the same as when the cranks were changed. It is possible that the porting is identical from all models in all small pins and all models in all big pins. I'd like to know for sure... Please post what you know.
Sure, the 750SX and SXi watercraft use the same 743cc Kawasaki engine. But that base engine is also in several models, including the STS, the 750ZXi, and the SS model runabouts. These engines are the same, but different.
To get more horsepower, the SXi uses twin 40mm carbs, connected to a revised intake manifold that uses a balance tube to equalize the carbs' efforts for more low end response. For better top speed, the cylinder porting has been changed, without raising the compression. And to handle all this new power, most engine parts were beefed up for durability.
