New EME exhaust system for superjets!
Ericfox
Do it twice?That's DooDoo
I would only be interested if it worked for my ski... but my ski is only a limited ski... sounds like this is for higher modified engines. Doesnt b-pipe claim to have aboue 20% gain?
WaveDemon
Not Dead - Notable Member
Hell, Florida
this pipe requires a cart tank doesn't it?
nevermind. I checked.
attachment.php
THRUST
ThrustInnovations.com
i am sure there will be adapter plates in the future but due to a limited market it may be a personal mod done fairly easily . but it takes time to make a quality product . it will probably be offered in a 2.5 gallon and a 1 gallon and offer approx 25 to 1 hr of rum time depending on application
crammit442
makin' legs
here
Hmm, I wasn't excited about a 1 gallon tank, but a 2.5 gallon might be do-able.
Aaron
I have a 2.5 gal in my XFT hull and you do a lot of going back to shore to top off the tank. More than you would think. Not bad if you stay close, but not good in the surf or if you ride far from shore.
RiverRat
Louisville, Ky
My standard stroke lamey PV motor did well with a 9 litre tank. Lasted me a good 45 minutes of ride time. Kart tanks are the only way to go IMO. Really balences the ski out.
THRUST
thats correct it is a dry pipe . also it will be lighter than a b pipe . for those so concerned about fuel time keep in mind this is not designed to cruised around your lake or coastline this is a freestyle superstock pipe . also with the added increase in power compared to a b pipe you could run a single carb and have alot of power with good fuel economy .
I actually had terrible fuel economy when I ran a single TLR 48/44.
