Would it be possible to shorten the stock turnplate and run umi 0* bars? does any one have any pictures of this. I have tried searching for them but there doesnt seem to be any threads on this.
Cheers
i agree the umi set up is a pain in the arse it works better than stock at the beginning but after a few rides it is the same as stock with the exeption of shortened turn plate i am thinking of trying the jetski solutions set up with the nylon washer all his stuff is good cant see why this would be any different
any one try this set up?
Hey guys does anyone make a shortened turn (-1",-2") plate that can be used with stock superjet steering?
Cheers Mat
The only problem I see with shortening the stock turnplate and moving the bars forward is the fact that the underside of the bar will not be supported like it is in the factory setup. Not saying I wouldn't do the same thing, but it would be may be a good idea to cut off the bottom tabs and reuse them when mounting it forward.
Doug
Edit: I believe Mouth did the above in his writeup.
