Hi guys,
93 sj with stock box and using a light tester verified no spark, took ignition box off and inside is like new with not a drop of water or corrosion anywhere. Main fuse in the the little round o-ring sealed area is good with the same as batt voltage. I guess the coil is the one with the two plug wires coming out and the stator is the square box?nomenclature.
1) cut off ends of plug wires which were a little black and redid them with new clips that go on the plugs. No change.
b) checked continuouity by connecting the two barrel(or/bl)connectors and checked the plug wires.nothing. orange to the plug wire on that side and same for black. nothing.
2)engine ground is good with at batt voltage. Engine is shiny and with no corrosion.
I'm stumped.
thanx.
chris.
I'm stumped.
thanx.
chris.
