- Greenville, NC
I tried searching for this, but came up empty handed. If anyone could let me know what a 650/701 stator should ohm out at, that would be great, thanks!
I havent had to go thru this with a yama ( knock on fiberglass)
but on the old kawasaki I had to figure out, I could see the different voltages from the coils during cranking.
pulser coil was like several volts.
lighting coil was 40-60 volts AC
cdi charge coil was similar to the lighting coil.
all the numbers were usually bigger the faster the flywheel was turning.
Thanks for the link, kennay.
I tested it out at: 400 ohms on the charge coil (brown/white to ground wire)
17 ohms on the pulse coil (white/red to ground)
Can anyone chime in on whethere these are suitable numbers?
I got 394 brown/white to ground
and 17.xx on the red/white to ground.
Id say youve got a working stator there, as long as it doesnt break down under heat.
