Somebody told me we are going to get some waves this weekend.
Where are we riding? Beach zones will most likely be closed due to small craft advisory. North swell means South side of Ponce and Shark shallows will be good and secret spot will be good at least in the mornings. Somebody talk to me, I am getting ancy. I'm going to get gas now.
Garratt, that sucks! Your motor was way fresher then mine.... same motor setup.... hope it wasnt the builders fault.
Wasn't the builder's fault. I guess it's on me, but I would share a little blame with ATP. Their manifold covers the center intake bolt hole. The gasket covered that hole and I forgot about it. It ended up leaking enough air to badly lean out the rear cylinder and melt the piston. I got all that under control and was about to get ready for reassembly when I found a piece of the front piston missing. I guess it's the same issue, but I'm not sure. It's missing a piece between the two rings, but otherwise looks good. more $$$ I don't have to spend right now. Exactly 32.5 hours on it. I have a tiny tach installed since new and it tracks engine time.
no sense in procrastinating.
wonder if the wind will cooperate. with how fast it will be pulling away from us, do you think the swell will die quick?
Swell should be good through the weekend and the wind should be good in the am's. Low tide is in the morning so shark shallows should be breaking good. Pontoon is ready. I'm ready. I think I could go lift my ski onto the deck right now while the boat is on the trailer.
Im down for Ponce... Christian and Havell were talking about it before, then I mentioned Sebastain... But im down for Ponce.... secret spot is just to far....
Lets make it Ponce... maybe I will just sleep in my truck for one night.
Don't sleep in the truck. You can see the light house from the end of my road. Just make sure you are not the first to pass out.
DCRocks
Wavejunkies
Washington DC
I hate you guys! :tongue2:
Been listening to the weather report all last night, and how it is talking about 10-14 foot waves off the FL coast. :grumble:
Time for some serious :brap:
Hope the waves are not blown out, and you get many sets of the perfect breaks! :Banane35:
Y
yamaslut
Ted and I will be at the beachbreak...
It's right in front of Perry's
Y
yamaslut
I would love to go there. Small craft advisory and torn up beaches are going to say otherwise. I figured our only chance is one of the inlets. Maybe by Sunday the small craft will be lifted.
If we can't get on, I'll go over there... we should at least try...
Y
yamaslut
noaa states SCA for hazardous seas through Sunday afternoon. That could change. Noel is moving out quick.
We'll see if things change throughout the day...
The wind is suppose to die down today...
when you all say "early" what time do you actually mean? It's gonna be pretty cool at 71 degrees but I'm itchin to ride some cleaner surf instead of the poop I rode last Sunday. If it's anything like the pics you all took from last Sat in the beach zone....I'd be stoked for sure.
