- Carlsbad, CA
1994 701 Superjet b-Pipe 170 psi.
Just installed an MSD and cranked the rev-limit to the max. On my Pro-Tec modified CDI I had the limit around 7500 and I had no bottom end issues.
With the higer rev limit the prop seems like it does not hook up as well when coming out of the water at low speed. High speed everything is fine.
Is it possible that spinning the prop at 9K at low end kills some bottom end hook up? Or is it my skat 9/17 standard just not good enough at 9K (low end)?
