96 rn rebuild/wcf parts
time to rebuild the super jet.
parts should be here this week
wcf top deck
wcf hood and carbon nose piece
wcf carbon ride plate
front exhaust
scupper
wcf foot holds
motor
i dont know what iam doing yet
up for some advice
[/IMG]
[/IMG]
SXIPro
JM781 Big Bore
Check out his first post!:rolleyes:
I use a good brand epoxy with milled fibers. I also reccommend using Plexus if you can find it
you can find almost everything you need here www.uscomposites.com
That's not what I meant. I realize he is buying a bunch of stuff from you to replace what he is removing, I am wondering what he is doing with the stock parts he is tearing off.
So, ahh, check out my original question... :poke:
sjetrider
NICE BUILD BRO, should be a great boat. I got a lead on Plexus if you want PM me for info. I also have the $85.00 gun you can borrow for applying the Plexus. I believe the Plexus was $40.00 per tube and will take nearly 2 tubes to do the entire job, the left over can also be used installing foot holds if you want.
