- Reno,NV
Hi ,
I had a thread a while ago about a ported 701 protec and now I am back, finally got arround to rebuilt the engine and here is whats going on.( ELEV 5500 feet ! ).
- 701 Protec cylinder, new bore & hone, 82,0mm 135 PSI on both.( in my opinion still to low, I want higher compression therefor
- Pro tec head >> will have to be replaced I assume.ANY HIGH COMPR HEADS I WILL PAYPAL IMMEDIATLY !
- Coffmans exhaust
- 44mm SBN ( i have several carbs with different jettings ).
>> ALL FUEL LINES ARE CLEAN,ALL FILTERS EXTERNAL/INTERNAL ARE CLEAN,I HAVE DIFFERENT CARBS WITH DIFFERENT JETTINGS ANYWHERE FROM 2.0-2.5 N&S JETS LOW 120-140 HIGH 135-150, it does not seem to be a fuel problem.
-650 ELECTRICAL,Stator, no cvhanges made.
The Sympton
The ski runs, has no real low end, idle good, gets up to speed but not full speed I can feel it.....no bottom end rip at all.
BUT CHECK THIS
WHEN I JUMP GOING STRAIGHT the SKI SUDDENLY GETS POWER, basically when out of the water, then it somewhat catches on and I have HIGH END but as soon as I let go of the gas and then accelate again nothing.
-CAN THIS BE AN ELECTRICAL PROBLEM ? STATOR ? REV LIMITER ?
-SHOULD I GET THE COMPRESSION HIGER FIRST ?
2 weeks to HAVASU and I need this ski running/
Thank you
Chris
- Coffmans exhaust
The Sympton
BUT CHECK THIS
Thank you
Chris
