shawn_NJ
Chasing waves.
- Daytona Beach
I need advice asap! My 780x2 sucked in a massive seaweed chunk today. This clogged the pump enough that water was not flowing through the ski. The sun glare was so bad that I did not notice the pisser was not flowing. After an unknown amount of time, the stinger cooling line melted. Ski would still start fine at this point. So I got towed in. Now I get home, replace the cooling hose and run the ski on the hose. Runs fine for 5mins, motor is just warm to the touch, revs nice. Then as soon as I go to shut the hose off the motor dies on its own at idle. I shut the hose of within a second or two and ran over to the ski to restart it. It fires, then dies after 2-3seconds. I checked spark which is fine and topped off the gas tank. Plugs appear wetish with gas. I am at a loss with this one! I dont have compression gauge here, but the finger over the hole test seemed to be consistant with a good pop on each cylinder. Without a compression test is there anything else to look for?
DID I KILL THIS MOTOR TODAY?????
