Replacing a ring gear
What`s the best way to remove and replace a ring gear from an alloy flywheel.
Heat the ring or freeze the hub ?
G
Goose
ring gear
i did a ring gear on a msd total loss all i did was heat the ring gear and tapped it with a punch and it came off real easy same with installing a new one just heated the ring and it slid right on
Yes you can just heat the ring gear and drop it on the flywheel.We used to replace them on Seadoos on a regular basis before they changed the engagement on the starters.
