Quick question..... 650 manifold on 701?
djyox
Old school -not by choice
Twincities, MN
I am just wanting to know if the 6m6 650 manifold will work on the 61x 701 case. The stock manifold does say 6m6 on it, but I don't want to get a part and have it turn up to be wrong...
Thanks for helping me answer this guys!
Oh and also, what about reeds? are the 61x reeds the same as the 6m6?
:headbang:
Yes, it will work. The port shape will be off, though.
Nothing that 15 minutes of grinding cannot fix. I believe the runners in the manifold may be smaller, too.
FWIW, I run a 650 FPP manifold on my 760 cylinder. It took a bit more than 15 minutes of grinding, but it works great. The outside dimensions are the same, it's just the inside that's different.
Reeds are most definitely not interchangeable.
EDIT: What I said applies to exhaust manifolds, not intake manifolds.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
are you sure matt?
if he is talking about INTAKE manifolds, I dont they they will bolt on place of one another.
I can check for sure when I get home, but I think the 701 is slightly larger.
the reeds are different as well.
DOH!!!! I thought he was talking exhaust manifolds.
NO, the intake manifolds are 100% not interchangeable.
djyox
Twincities, MN
They look the same... I just can't tell and I don't want to waste any more of the sellers time than I have to.
That would be great if you checked! I've never seen the answer anywhere.... Just that the 61x manifold does infact say 6m6 on the top...
Mouthfulloflake
ISJWTA member #2
NW Arkansas
it SHOULD say 61x on top.
the ones ive seen do.
You're both wrong. :fingersx:
I happened to look at 2 650 intakes yesterday, and they say 6R7
Mouthfulloflake
ISJWTA member #2
NW Arkansas
I see.
you asshats have never seen a 61x intake?
on the left ( black) is a 650 intake, it has that 6r7 on it.
the other ones have........ [drumroll]
61x on them.
:beerchug:
djyox
Twincities, MN
Ok, I've got to take a picture tomorrow, because I'm sure mine says 6m6 on it where yours says 61x...
Then again I could be completely wrong and will end up looking like even more of an asshat (I love that word! I haven't seen it used for a few years though, guess I'm hanging in the wrong crowd)
djyox
Twincities, MN
I ment to check before work tonight, but I forgot.
I remember it said 6m6 somewhere down there, and I was sure that was it. I need to work on it tomorrow AM so I will check then and post.
The cyl say 61x tho....
