douglee25
m3booooy
- South Jersey
Ba!
Turfing is done, it took over 8 hours for Chad and I to do this. Since the tray had extra room, we turfed in some subtle lifters in front and behind the footholds to see if they'll be helpful for riding out of the footholds. Side panels are one piece no seams. Nice think underpadding on the tray, in the footholds and shaped into a kick tail, tray is damn cushy. I broke a foot a few years ago, and prefer really soft turfing.
more pics, assembly starts tomorrow. I'm still waiting on some texilium, but I can install the pump, poles and lots of other odds and ends.
Ok I will ask,what exactly is wrong with drilled and tapped aluminum for inserts?
I put in about 5 hours in the pump area today, grinding on the tilt nozzle and shimming and 5200'n the pump shoe and pump today. Turns out my gap wasn't acceptable between the pump shoe and the rubber gasket. I had to shim my pump shoe out with washer and re-glue it to make it right. The tilt nozzle would also bind up and stick when tilted up and turning, Did lots of grinding to make it work. For once I have a tilt nozzle that doesn't automatically turn will the tilt lever is pulled, doesnt bind or stress the steering cable at all( steering cable thru-hull location was moved up directly in line with the turn nozzle, above the pump cooling boss (pic is inverted). White 5200 makes a heck of mess on black paint.
Sides are reinforced with a layer of biaxial and texilium is layed over the top. I hate working with texilium and will never do inside a hull again after this build. I will use a color cloth next time.
Pole and engine to find their new home tomorrow.
