aranka
usually drunk
- Detroit River MI
i am completely baffeled by what is happening with my ski. Here's the setup: Kawi 750 SX, Factory Pipe, MSD Enhancer, Single 53 Mikuni Carb, 150 PSI both jugs. The problem is that the ski rev's up completely out of water, then once it gets a load (water) it dies to about 1/3rd power. I cannot get this thing to run properly. Here's what I've done so far
1. New Coil
2. New MSD enhancer
3. New Starter Relay (i broke old one)
4. Checked reeds, head, head gasket, compression, exhaust, fuel delivery from pickup to carb, i pulled the pump and there is no hang up at all there.
the flywheel is stock and the timing is advanced.
5. New fuel filter.
6. Carb was rebuilt and is in mint order.
This is the same setup as my buddies and his has no problem. Any ideas of what it could be??????? I am so freaking frustrated that i want to sink it!!!!!!!!!! I've even run the ski with no hood and F/A and tried cracking the gas cap. I've tried everything i can think of including voltage and ohms tests everywhere.
1. New Coil
2. New MSD enhancer
5. New fuel filter.
