hull insert pulled out of hull!!!!
ANT
Just ride
the hull insert in my ski actually wobbled out of the bottom of the hull. I was riding the other day and my driveshaft and short shaft splines stripped out. so i pulled out my motor and saw that the one rear left mount was just kinda of hanging out there. the front insert is fine but the rear had completely loosened out of the hull and the motor mount vibrated about a 1/4" into the hull. so i cleaned it all out with acetone then sanded everything down with 40grit then filled the hole with 404 filler, pushed the insert in then filled all the gaps with a west system syringe and filled all the areas where the motor mount vibrated into the hull. should have it running again tommrow, unless i feel like working on it again tonight. here are some pics.
