My Kawasaki 650SX
LKN
It has a few extra pieces: an AC aluminum handle pole, 44mm Mikuni Super BN carb on a BCW intake manifold, Coffmans exhaust system (header, pipe, stinger), aftermarket rideplate and intake grate, primer, and dual bilge pumps.
Unfortunately, it has lost its spark, so it may be going up on the market soon. :headache:
SKItarist750
Custom Kawi
Lansing, MI
If you're not getting spark, check your stator to make sure it's in good order, and check the connections where the stator wiring plugs in to your CDI box. It's probably one of those and if your stator is bad, you can prob. get a good cond. used stator from Havasu Watercraft at 800-680-6621. If the stator is not the problem you probably have a bad ground or spark plug boot connection. good luck, but if you can't figure it out, sell and get an 800:147:
Vumad
Super Hero, with a cape!
St. Pete, FL
Don't sell the parts until you have donated the coffmans, to me of course!
Paaaweeeeeezzze :puppy_dog_eyes:
:laugh2:
LKN
After reading through the Shop Manual and looking inside the hull, I have come to the conclusion that I have neither the correct tools or skills to start tearing things apart. :sad:
Below are some more photos of the ski. It has a K&N air filter, but I took it off to trace the electrical cables.
