alright here is where im at. i cut the other hole out and took the foam out
here is the issue that i was speaking of earlier though. even with the rivits in the hold is still not flush. i talked with paul at lpw and he said he encountered the same issue doing these.
here is the one i have rivited already
the gap in front
the gap at the top
the hold that is rivited in was the one that was better fitting, and it isnt even going flush. i am very concerned abt the one on the right bc it is a lot worse fitting.
here it is with the back pressed flush
and with the front pressed flush
and these things dont flex easily. will the small gaps on the one on the left be ok once i fill with foam and glass over them? any tips on getting the right one flush
