- Carlsbad, CA
My ski started running bad a few weeks ago. It acted like there was some sort of carb problem because it would not obtain max RPM. It is the kind of power like running on one cylinder (but both are firing), max RPM of maybe 4k.
I tore into the carb and all seemed well. Then I took off the intake and one of the carbon Tech reed pedals on the front cylinder intake was broken.
Can a broken reed pedal cause the engine to not achieve max RPM? I think not because at max RPM the pedals are open correct? So it would be a throttle response problem not a high RPM issue correct? Am I wromg? I am just thinking I have another issue.
(I have not repaired the broken pedal yet)
JC
JC
