building my 701 sj need input
chrisdoc0608
insulting
rocky mount, nc
im going to be getting a complete minus ebox 61x this weekend for $200. the top end is shot, and the crank status is unknown. i have a 62t bottom end that is in pretty rough shape, so depending on if it is salvagable or not i may just stick with the 61x motor whole. anyway i need some direction as to what i should do to this motor as far as porting, boreing out, ect. i am going to be on a college budget, so i dont want to spend a ton. my plans are to run the 46mm carb i have on my 650 now, the coffman pipe i have upgrading to a factory b at some point, i also want to put an ada head with mabye 35cc domes for pump gas. i need suggestions on:
1)what reeds to use.
2)where to get ported for relatively inexpensive or do the templates you can buy work well, i wouldnt mind doing it myself.
3) what bore should i go to, bc i figure i might as well go oversize if i have to bore and replace pistons anyway. 83mm??
4) what order do i do these things in, bore first then port or port first then bore. i was thinking the second one sounded better
5) can i get a 701 manifold that my coffman pipe will fit onto? i have read that cutting the 650 manifold to match the 701 exhaust ports is risky bc they make it too thin.
6) what brand pistons should i be going for?
my main objective for this motor is to have some really good power all around, mostly bottom end bc i love attempting freestyle, and hopefully i will be much better by the time i have this done :brap:
thanks in advance for the help
-chris
Mark44
Katie's Boss
100% one place
u
-chris
Everyone will have there opinions on this I would contact a few engine builders and talk with them such as Chucky or Paul for there impute.
Mark44
SuperJETT
none
Carbon Tech
Get the Sport Port templates, they do work very well.
83 is the normal limit on a 61x cylinder, so if you bore to 83, then have a problem, you need to resleeve. Go the next size up to remove any damage, there is minimal gain from 1 or 2mm bore.
if it needs bored, get it done. If not, just ported.
no idea
Pro-x or oem
-chris
Mark44
Katie's Boss
100% one place
I use Boysen glass reeds.
I do not have time to sit around and do porting so I have it done.
No idea on the manifold
I use proX pistons that’s what the builder recommended.
